HELP: fuseable link for fans
Old Aug 19, 2003 | 09:46 PM
lillbush5555's Avatar
I cant keep the fusable link for my cooling fans to stop burning up...is there anything I can do to get it to stop...I tried to take it out and put a 25 amp fuse in and it worked for a while, but that burned up to..so I need to to get a new 1 but the parts store say I need to know what size cuz there are like 10 differnt ones...what size should I get and is there anything I can do to get it to stop burning?
thanks
matt
Old Aug 19, 2003 | 09:56 PM
There must be some excessive current draw for the fusible link to burn up. Maybe one of your fans is dying and pulling too much juice or a fan relay (or even wiring) is shorting out.
You might stick with the fuse until you get it sorted out. I believe the fan wires should use a 1 sq. mm fusible link.
Apr 27, 2015 06:08 AM
DrMilhouse
Aug 6, 2002 08:45 PM
sc93
Jul 26, 2002 02:02 PM
