Help code 42 electronic spark timing circuit grounded
Old Sep 10, 2013 | 02:51 PM
sabedra211's Avatar
Hi I just replaced opti (again) and it was running fine. Now car starts bucking and hesitating when it warms up. I got a code 42. I replaced icm and still code 42 also getting a code 16 in stored. I tried resetting pcm and code 16 wont clear but code 42 does. I checked my wiring on the icm and opti harness and the voltage readings are good. Could it be my opti again? The icm harness had 12.4 v on A and B was around 3 volts but when i stopped cranking it I jumped to 7-8 volts ac. C was 0 ohms and d was like 11 volts. Opti harness was 5,5 , 12.4 and 0 ohms. What can be causing this problem? As soon as it starts bucking code 42 pops up. No ses light. Thanks for any help
Old Sep 21, 2013 | 09:55 AM
Max 93's Avatar
Re: Help code 42 electronic spark timing circuit grounded
Last time I had a code 42 it was the ignition module
Iamherefornow
Jan 26, 2015 04:57 PM
Jan 23, 2015 01:13 PM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
