help on choosing cam/headwork
ok, i have my 95z28 of course, it had overheated, so im not sure if headgaskets are gone.. while its apart i just figured, that i would get, electric waterpump (because the gear tht drives it f'd up and i wont have to worry about tht gear now) new timing chain, cam, lt1/lt4 headgasket (something thin to bring compression up), and possibly send out the heads to get worked on, port n polished... exc.. depending on the came i would get. (my heads are stock aluminum). my stall speed is 2100ish. (built 4l60e) and i have an aubrun posi with 3.73 gears in the rearend. what do you think would be a good cam, that would still be emission legal (thank god im not living in california of course but still have emissions heh) and wht kind of flow should i get my heads done at/ springs/ rockers and tht sort, thx
Re: help on choosing cam/headwork
I went with a heads and cam from Lloyd:
http://www.eportworks.com/
Another option is:
http://www.advancedinduction.com/
Can't go wrong with either.
Another option is:
cmsmith
Jun 24, 2015 12:36 PM
CARiD
Jun 18, 2015 08:56 AM
Jun 5, 2015 10:16 AM
