Help! Car won't start.. errr..
Old Aug 26, 2003 | 12:59 PM
dthomas's Avatar
Angry Help! Car won't start.. errr..
I am not sure if it is the starter or something else, but when I put the key in the ignition and turn it over to start all power just goes away. The door chime, my stereo, lights, etc. It is a brand new battery and voltage is good on it. I have to pull the key out of the ignition and put it back, then I hear a relay pop and the power comes back. I did notice that on my way home yesterday that the car was running a little rough and the voltage was sitting around 12.9-13.2 volts.
Any help would be appreciated.
Thanks,
David
Old Aug 26, 2003 | 01:05 PM
BUBBA's Avatar
Sounds like bad battery connections. JMHO
Old Aug 26, 2003 | 01:39 PM
turbo_Z's Avatar
sounds like bad battery connections to me... happened once or twice but it might also be the ignition switch.
Old Aug 26, 2003 | 04:10 PM
dthomas's Avatar
Well that would be awesome if thats all it is. I had to get a new battery about 3 weeks ago(stereo abuse and 5 years old). I am wondering about that purple goo that kragen told me to put on the terminals. Also the bolt type thing that goes through the cable into the battery is striped so I have use vise grips to get it on and off. Would kragen or someplace like it carry that piece?
--David
Old Aug 27, 2003 | 08:30 PM
dthomas's Avatar
Thanks!!! It was a loose connection to the negative. I think when we were testing for draws after replacing the battery we didn't tighten up the negative that well..
Thanks again,
David
Britbilly
Jan 7, 2015 08:49 PM
CARiD
Dec 26, 2014 04:20 AM
Dec 4, 2014 11:56 AM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
