Help!!! car wont start!!!!asap!!
Check if you are getting spark by pulling out a plug wire from the plug. Stick a new spark plug on it (anything really) and crank the engine while you hold the plug boot with the plug about 5mm from a ground terminal (usually a bolt on the engine block). You should see an electric spark come out of you are getting spark.
If you are getting spark, it means there is something wrong with your fuel system - probably inadequate fuel pressure.
Good luck.
BTW, was it running good yesterday?
Good luck.
I doubt it. An opti will show signs of failing before it dies - very seldom 'just dies'. Mine got drenched in water (opti's hate moisture) and it started just fine but when you drove it, it would hit some sort of a rev limiter at about 3500 rpm.
A coil is usually the cause of a 'no spark' condition. I'd say go to Autozone with the ignition coil and ignition module and have them tested. If they're alright, most probably you have a bad wire from the weather somewhere or it's the fuel system like I mentioned earlier.
Is your starter OK?
Is your starter OK?
Do your lights go on if you turn them on? If so, your battery isn't in question. Jumping should get a weak battery back ontrack provided that your alternator is fine. A friend of mine works in Autozone, they'll test the module and coil.
had autozone test coil,....its fine..they couldnt test module though....
update...yesterday i tried cranking like i have been...i tried something new...pump the gas! then suddenly i acted like it wanted to start.... so i keeped at it for 4 or 5 mins...pumping and cranking...then suddenly IT STARTS!!! i immedially drove it to my mechanic. I runs perfect drives perfect...no hesistation what so ever.... this is the second time its done this. could it really be a opti? it runs perfect once its started. it did this 3 weeks ago... then it was fine...Anyone have any ideas??? bad starter? it cranks but who knows...
thanks guys!!
shawn
thanks guys!!
shawn
