HELP car wont start
Old Sep 10, 2003 | 04:57 PM
  #16
BUBBA's Avatar
If it is your pump, you are going to have to drop the tank to deinstall the stocker and install new one.
Advise you pick cheap siphen and remove most of the fuel. It's heavy.
Actually, having a qualified mech do it, if you can afford it, would be my druthers.
Ran mine dry one time, but I guess I was lucky.
Old Sep 10, 2003 | 04:58 PM
  #17
RamAir95TA's Avatar
Originally posted by THE HULK 95 Z28
Just checked your link. Isn't that dangerous? I just put $15 of gas in before it stopped starting. Also, is it easy to change the pump once the cut is made?
I'm still alive, aren't I?
It's really easy actually. A cutoff wheel is less than an 1/2" in diameter, and there's a good 1" of space between the trunk pan and the tank. If you take your time and do it right, and most of all use common sense, you'll be fine. Once you have the access panel cut, removing and reinstalling the pump is fairly simple, as long as you have a good set of directions, or a website to help you along the way.
Old Sep 10, 2003 | 05:01 PM
  #18
RamAir95TA's Avatar
A mechanic will easily charge you over $500 for a fuel pump install. Not worth it in my book, if you have an easier method.
Old Sep 10, 2003 | 09:12 PM
  #19
THE HULK 95 Z28's Avatar
Found out what was wrong!!!!! It was my MSD ignition. It crapped out. All I had to do was disconnect it.
Noenav
Mar 1, 2019 07:38 AM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
