help! car stutters at 2200 rpm
Re: help! car stutters at 2200 rpm
I am not too sure where they all are but check the one that is on the bolt that holds the coil on. Mine was corroded and was causing some problems. Also you can just ground the car out temporarily hook a strap from a good ground source on the frame, and go for a ride see if it solves the problem. If you have a friend with a similar car borrow their coil, and ICM bolt them to yours and try it out. If none of those work then I would say get it scanned (if you already havent) see if anything comes up, and then try the opti again. I am almpost 99% sure its your opti. All the symptoms were exact to the "T" when mine went. Check those things i mentioned especially making another temporary ground to see if it corrects the problem. ICM and coil are another possibillity. Before my opti went out it took my ICM once and coil out at two separate occasions Its probably why i travel with an extra coil. Once the opti crapped, I fixed it and all my electrical problems were solved.
Originally Posted by oneslowz28
Well guys the problem stoped for a while and i figured all was good. But thats what i get for thinking. Took the car to the track lastnight (read my post bad night at the track) and to say the least the prob. is back. this time much worse . the car stutters under a load again but there are times i cant get over 50 mph. I thought it might be the fuel filter so i replaced it and it needed it the fuel that came out of the tank side of it looked like used oil. so i droopped the tank and cleaned it out and i thgought this would fix the prob. well after finishing up around 8 tonight its still "bogging" or "stuttering" under load. Im hoping its the cats when i check them tomorrow. the voltage is still fluxuating <sp>. we tested the alt and bat. and there both good i checked the voltage at the alt and bat. and there fine but if i check from a accessory like the cig lighter or a tail light its still juming from 16.3v to 10.1 volts. i checked it at a relay under the hood and its fluxauating just like on the inside. i checked all the grounds on the enging and body that were under the hood. is there susposed to be a ground going to the tranny? if there is i couldnt find it..
any ideas on what to check next if the getting rid of the cats doesnt work?
and anyidea what could be causing the voltage spike/drop?
This is very interesting.. first of all let me start by saying that if the Alternator is providing steady voltage below 15 volts... where does this 16.3 voltage is coming from?
Two possible answers... one is that it may be coming from some ignition voltage either jumping to or creating a magnetic transfer to the positive power suply. The problem with this answer is that anything conected to the power feeds would be affected but you are not measuring the voltage swings at the battery/alternator conection....
The second possible answer is that there is an intermitent voltage drop (possible corroded conection on either ground strap or rusted fuse contacts) that create what I call a low frequency alternating voltage swing.. in other words... the voltage intermitently drops and comes back up... swinging down and up and therefore creating an alternating voltage of a couple of volts... depending on how severe the problem is... This problem in my experience has caused some old test meters to display the wrong voltage values while using the direct voltage settings... I never took to time to analyze it why but I imagined the old voltmeters had some type of full Bridge rectifier set up at the input side and it was reading the voltage drop an adding it as aditional voltage being measured at the test conections... Its just a thought. I still wonder if the new digital voltmeters would experience the same problem.
Point being is... the 16.3 voltage you are measuring, assuming the reading is accurate, has to be generated from somewhere. weather is magnetically induced from the ignition High voltage side to the power feeds or the alternators voltage regulator is randomly fluctuating the voltage when you are not looking...... Yeah it sounds funny but I have seen some weird stuff before...
if anyone has any other ideas that would explain how the voltage is swinging up higher than the actual voltage feed from the alternator I would defenetely be interested in listening.
Marvin
Ok here is another thought.... does the PCM control the alternators voltage regulator output via that wire conection that plugs right behind the alternator itself? I am not talking about the positive power output but the one that activates the alternator? Sorry I dont know the correct names of everything. I was just thinking... does this PCM hook up works like a switch ? on and off as the only possible status or does it actually act as a regulated voltage feedback?
There is a slight possibility that if this set up uses the PCM not only to activate the Alternators output but to control how much voltage is coming out.... if there is a bad conection somewhere it may send intermittent direct voltage into the voltage regulator and compounding the problem...
Its only a thought... anyone know how this chargin system actually works?? if it only activates the Alternator as an on and off switch.. then disregard this post...
Marvin
Marvin
sleeperZ96BT
Jun 5, 2005 09:33 PM
