Help! Can't Pull LT4 Timing Set! No Slack!
Old Aug 4, 2003 | 10:58 AM
  #16
Zepher's Avatar
Originally posted by sssalah
Can't you just pull out the dowel pin. I've pulled out my pin with a plier and reintalled with a light hammer tap. That was a comp cam, not sure if it'll work with your cam.
Some peoples pins come out easy. My stock cam and LT4 hot cam's pins wuoldn't come out. had to use a vice.
Old Aug 4, 2003 | 12:29 PM
  #17
turbo_Z's Avatar
you should have rotated the crank to #1 TDC and it would have come right out. if you were able to turn the crank possibly by attaching the hub back on or just trying by hand then that cam sprocket will rotate around and give you enough slack to pull the chain off.
Old Aug 4, 2003 | 12:46 PM
  #18
Mikey97Z's Avatar
Originally posted by shoebox
I really don't see why that should not work. If the cam dowel is at 3 or 9 o'clock (or lower) and the 3 bolts are out, why won't it pivot down and create slack in the chain? I pretty much did the reverse to put my set on.
By the position in your pic, I can see how there won't be any way for it to pivot. The dowel is too high.
Thank you! I got it! Once the pin was lower, I was able to get it off. Now that I know, it was actually really easy. Kinda like most things.
HectorM52
Jul 30, 2017 11:46 AM
MadMav
Feb 6, 2015 11:02 PM
Gtpguy
Jan 26, 2015 04:50 PM
