help!!belt flew off and car is goinf crazy!!!
Old May 4, 2005 | 12:44 AM
street demon2k3's Avatar
i just got out of work and i noticed that my belt flew off. it isnt torn or damaged, and that is what scares me. i had to drive home without power steering or anything. the check gauge light was on, so was the ABS Inop, and my lights were real dim, also my speedo was going up and down. how is that possible if it is cable driven??? need help fast and i hope i didnt mess anything up. thanks in advance guys
Old May 4, 2005 | 12:46 AM
madwolf's Avatar
Re: help!!belt flew off and car is goinf crazy!!!
Put the belt back on and everything will be OK. The lights you got were due to low voltage.
It shouldn't have come off though.
Old May 4, 2005 | 12:51 AM
The speedo isn't cable driven. All due to low voltage like Ion said.
Old May 4, 2005 | 12:55 AM
Dave '97 Z28 M6's Avatar
Yep... agree with madwolf and shoebox.
You've just used one of the nicest design features of the LT1 to get you home... a gear driven waterpump that keeps coolant flowing with or without a belt.
Old May 4, 2005 | 12:57 AM
thanks for the quick post guys, i really appreciate it. i can sleep easy now thansk to you
ohh and i think the belt flew off after i did a little burnout in the parking lot earlier, before i got off from work. i remember that i did a 180* in the parking lot then i felt the sterrign wheel yank and it didnt move as easily. but i just ignored it cuz i ended up in the parking spot i wanted anyway. went back inside and then i saw the belt hanging.
Old May 4, 2005 | 05:07 AM
Fastbird93's Avatar
When you put it back on take a very careful look at all of your pulleys and make sure none are loose or wobbly. There's really no reason the belt should just get thrown off if everything is in proper working order.
RUDEDOG
Parts Wanted
Apr 24, 2015 09:47 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
