Help ASAP! LT1 Prob with Batt not charging!
Old Apr 13, 2005 | 10:45 AM
DemonZ28LT1's Avatar
I just found out that my battery was dead so I charged it and then found out it won't stay charged so I checked and it only put out 12v instead of the 14v when running and then I got it checked and put in a new alternator and then I check it again w/ new batt and alt. and still it's not charging the battery. Anyone can help me it would be great, this just happened and has never happened before.
Old Apr 13, 2005 | 11:06 AM
1-bad-z28's Avatar
Re: Help ASAP! LT1 Prob with Batt not charging!
when did you get the new batt? Before or after you started having problems?
Old Apr 13, 2005 | 11:13 AM
BUBBA's Avatar
If you are certain that all your cables are snug, you should take it to a pro and have them figure it out. JMHO
Old Apr 13, 2005 | 11:32 AM
Evilfrog's Avatar
How is your starter? Does the car act like it has a dead battery sometimes when you turn the key?(just goes "click") then if you turn the key again does it start?
Old Apr 14, 2005 | 10:58 AM
Cnadian_Camaro's Avatar
Ya how do you know its a dead battery ? Are you sure its not what your battery is powering that is not functioning..
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
blac94Z
Feb 6, 2015 10:40 AM
ro2207
Dec 4, 2014 06:18 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
