help
Old May 2, 2007 | 11:37 PM
93z28mike's Avatar
Unhappy help
I have a problem with power under 2k rpm. I have no power what so ever under 2000 rpm, but when its cold i dont notice it. but when its warm if i just get on it it miss fires out the exhaust. any ideas?
Old May 3, 2007 | 05:27 AM
Guest47904's Avatar
Guest
More info would be handy. We think you have a 93 but that's all we know. Do you still have an EGR?
Do you have a problem when it goes into closed loop? If so try disconnecting an O2 to force it into open loop all the time and see what that does. If it improves the problem, the solution is easy.
Old May 3, 2007 | 08:56 PM
93z28mike's Avatar
ya i have an egr and it is a 93. as far as i know the car is completely stock except for the cap and rotor which i did. but now i had a hose leak on the distributor and i think im goin to half to replace the opti spark
Old May 3, 2007 | 10:11 PM
RyanD's Avatar
not really a solution to your problem here, but join speeddensity.org, 93's are speecccciaal
