Help... ****** up parking brake
I pulled up the park brake and i guess i pulled it up to hard and it went straight up, made a large thud. Now the levers loose and the park brake doesn't work. I pulled the center console out and it appears that the cable is loose. what do i have to do? Do i have to tighten the cable? If so, how? THanks in advance.
Update...i looked underneath the car and saw that i snapped the cable. How hard is this to replace? Will i need any special tools or anything. I'll replace it sometime tomorrow morning. Thanks
When mine snapped,I had both replaced,because they strech,and I wanted to keep them even.I think it was about $45.00 for the cables.(now I don't pull as hard as before when parking.).Hope this helps.
It's not the easiest thing to change. Basically, you will need access below the car and you need to take the center console off.
Then you need to fish the new cable through the floor and around to the brake handle. There is a little lever on top of the rotating part of the handbrake. You will need to pull that lever back so that you can move the handbrake without tightening the cable. I think you'll see what I mean.
Good luck. It's pretty cramped. I made sure everything was hooked up underneath first, then connected the end inside the car. That's the part where you have to pull the little lever that rests on the gear teeth.
Dan
Dan
Originally posted by D-BoZ28
Thanks for the help guys. I'm still waitin' on the cable from the dealership though. The thing cost me 30 bucks. 30 bucks for a cable
Dan
Nellsw88
May 27, 2015 10:27 PM
Dylan Latshaw
Mar 21, 2015 09:48 AM
