Hei Distributor Conversion
Old Nov 1, 2007 | 05:04 PM
jninan2k2's Avatar
Does anyone have a write-up or information about doing a HEI distributor conversion on an lt1? I have heard of people doing it to take the place of opti.....if so any information you may have would be highly appreciated.
thanks,
Jacob N.
Old Nov 1, 2007 | 05:21 PM
Not possible unless you are getting rid of the computer, too. Besides spark and timing, the computer needs the opti signal for the fuel injectors.
Old Nov 1, 2007 | 06:02 PM
havoline42's Avatar
think you have to buy the intake from GM for a carb and hei
i may be wrong, i was going to do mine that way but you have to pull motor out to put dis. in i think
Old Nov 1, 2007 | 07:22 PM
jninan2k2's Avatar
I am just trying to find a way to get rid of the opti....the delteq sucked worse than the opti....i thought about buying a msd opti...but i hate the thought of spending almost 500 dollars on something not knowing what the hell to expect.
Old Nov 1, 2007 | 08:01 PM
The Engineer's Avatar
While there have been some problems with the MSD Optis, I still believe the MSD is this the best option for LT owners. With the upgraded rotor screws w/ thread-locker and square O-ring, my MSD has been working great in my LT-4 bracket car.
WD
Old Nov 2, 2007 | 11:52 AM
Vicious95Z28's Avatar
What about the Vortec dizzy? Is it possible to make it work?
Old Nov 2, 2007 | 12:02 PM
I've heard rumors of someone putting the Opti optical sensor in a conventional distributor. It would work, if you could fit is in there.
But, all things considered, my engine's been running for 8 years now off only the optical sensor, still mounted in the Opti case. I did do a "vented" conversion though. A friend of mine with an identical setup made 1,125 very reliable HP in an 8,000rpm LT1 using the stock optical sensor.
I would not write off the Opti because of your experience with Delteq. I've seen at least one post at this point (not on this board) from someone who could not get the Delteq to work satisfactorily, and claims the people at Delteq recongized that the unit simply would not work right on some LT1's and refunded their money.
I think the LTCC makes more sense, and my setup is similar, with the 8 LS1 coils, but I don't have first-hand experience with the LTCC.
Old Nov 2, 2007 | 12:07 PM
What is your set up Fred? You said it was LTCC similar, now I'm curious.
Old Nov 2, 2007 | 04:46 PM
Opti optical sensor sending cam and crank reference to a MoTeC M48Pro ECU, with the MoTeC IEX 8-channel ignition driver firing 8 LS1-style coils. Its not my design.... I stole it from George Baxter's 9.05-second 30th SS convertible.
http://www.injuneer.com/images/photo...ne/Coils01.jpg
RUENUF
Mar 13, 2016 03:37 PM
68camaroboltz
Oct 5, 2015 01:46 PM
autoxr166
Sep 25, 2015 04:21 PM
tdigger9899
Sep 7, 2015 10:56 AM
gonzo275rltw
Jul 11, 2015 04:19 AM
