heeeeeeeeeelllllllllllllppppp dumping fuel!!!
Old Jul 28, 2008 | 04:20 PM
green96ta's Avatar
well i figured out that my car wont start because it is just absolutly dumping fuel. like all of the injectors are pulsing all of the time. when i put new plugs in and can get it to start it just revs up untill it dies from not getting any air...someone help please. i just had the computer retuned by ion....is there anything that could be wrong with the tume? someone please help before i seriously burn this car to the ground.
Old Jul 28, 2008 | 06:16 PM
green96ta's Avatar
hmm
anyone have any ideas?
Old Jul 28, 2008 | 07:09 PM
irocbsa's Avatar
If its really puking fuel like that, there's either something seriously wrong with the tune or a piece of hardware in the fuel system coincidentally failed. So you're saying that the issue started as after you installed the ECM with the new cal? I would definitely say start there. Go back to a stock cal and see what happens.
Old Jul 28, 2008 | 07:14 PM
green96ta's Avatar
ok...this is weird
ok. when i removed my timing set the timing marks were at 12 o clock and 12 o clock for both the cam and the crank. well i looked at shoeboxs install guide and it says one should be at 12 and one should be at 6. im really confused. mine came off the opposite, and it ran before. i sure hope i didnt warp all my valves. i highly doubt i did cause i have got it to run, but it just revs up untill it dies. wouldnt start at all if i bent the valves likt that.
Old Jul 28, 2008 | 09:16 PM
SS RRR's Avatar
For what reference point? 12 and 12 is #1 at TDC. 12 and 6 is #6 at TDC (TDC meaning at the top of the compression stroke ready to fire).
Old Jul 28, 2008 | 10:32 PM
green96ta's Avatar
im gonna re check it tomorrow
im gonna recheck it tomorrow. im willing to bet that 6 was at tdc and i timed it as if 1 was at tdc.i say this because i am a retard and when i removed the transmission for the torque converter install i moved the crank to get the converter bolts out, thus changing the reference. sometimes im quite the blonde.
HarleyZ28
Oct 5, 2015 06:23 AM
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
QuickSilver02
Apr 7, 2015 11:12 AM
NewsBot
Jan 23, 2015 01:10 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
