Heating up on Highway
Old Mar 3, 2007 | 02:43 PM
  #16
LiENUS's Avatar
Originally Posted by LT1_King
the front air dam is inplace everything seems. fine. we're gonna replace the thermostat and we'll go from there.
Did he get ground effects when he lowered it? you never really answered that
Old Mar 3, 2007 | 05:25 PM
  #17
TobyZ28's Avatar
I had your problem before WITH my airdam in place. What it was was the plastic baffle that is located just below the wiper fluid resevoir. There are these plastic push in pins that hold it in place, if the pins came out, the plastic baffle will push down at highway speeds and lay flat across the radiator, and temps will rise. If you slow down the plastic piece returns to "normal" and no longer is up blocking the radiator.
To find it, pop the hood, look down below past the water resevoir. You can also look under the car and folllow tip of the nose back, to the first joint. That joint is where the 3 pins that hold that "baffle" are. Hope this helps
Old Mar 3, 2007 | 07:03 PM
  #18
LT1_King's Avatar
he lowered it himself. it doesn't have no ground affects.
Old Mar 3, 2007 | 07:04 PM
  #19
LT1_King's Avatar
thanks for your help let me go see if this is the problem right now. i'll get back to you.
Nayr
Mar 3, 2023 08:34 PM
Louey
Pacific
Oct 1, 2015 12:37 AM
CARiD
Sep 30, 2015 05:44 AM
drt
Sep 27, 2015 04:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
