Heater Hoses
Old Aug 4, 2005 | 02:47 PM
EKO's Avatar
EKO
Heater Hoses
I'm trying to get all the heater hoses set up for my LT1 swap, and I've run into a little confusion.
Looking at shoebox's diagram of the heater hoses on the 94 LT1, I'm a little confused about the tee that connects a heater hose, the throttle body heater and the hose that goes to the water pump. Is this tee a heater control valve or just a standard 3/8" Tee junction? If it's a heater control valve, where does the vacuum line to feed it come from? Thanks.
Old Aug 4, 2005 | 05:41 PM
Re: Heater Hoses
There are no heater control valves on a 4th gen.
Old Aug 4, 2005 | 05:50 PM
EKO's Avatar
EKO
Re: Heater Hoses
I didn't think so, thanks!
On the other hose diagram there is the upper hose with a 3/8" (I think?) hose that goes to LH side of the throttle body. Is that integral with the lower hose? Or is there another tee fitting (labeled 14 on the diagram)?
Old Aug 4, 2005 | 06:14 PM
Re: Heater Hoses
If you mean #14 in this diagram, it is all one hose. If you are going to bypass the coolant hoses into the throttle body, just use the 1995 hoses.
Old Aug 4, 2005 | 06:21 PM
EKO's Avatar
EKO
Re: Heater Hoses
Thats the one, thanks!
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
