Heater Hoses
Heater Hoses
I'm trying to get all the heater hoses set up for my LT1 swap, and I've run into a little confusion.
Looking at shoebox's diagram of the heater hoses on the 94 LT1, I'm a little confused about the tee that connects a heater hose, the throttle body heater and the hose that goes to the water pump. Is this tee a heater control valve or just a standard 3/8" Tee junction? If it's a heater control valve, where does the vacuum line to feed it come from? Thanks.
Re: Heater Hoses
I didn't think so, thanks!
On the other hose diagram there is the upper hose with a 3/8" (I think?) hose that goes to LH side of the throttle body. Is that integral with the lower hose? Or is there another tee fitting (labeled 14 on the diagram)?
Re: Heater Hoses
