heater hose replacement
Old Mar 15, 2005 | 05:55 PM
slverbullet's Avatar
when replacing the old stock heater hose with the goodyear hose, you need to disconnect one of the old hoses from the bleeder section to place on the new pieces. how do i go about removing the bleeder section? should i just use a saw and cut the pipe at the ends to remove the old connections? or do the connections at the end of the hose just pop/break off of the bleeder pipe? i dont want to break this thing, so thats why i'm asking. thanks for any help.
Old Mar 15, 2005 | 07:00 PM
Re: heater hose replacement
To replace the individual rubber hoses, you need to carefully remove the crimped collars without cutting into the pipe underneath. You need that pipe to clamp the new hoses to.
Old Mar 15, 2005 | 08:47 PM
Deckstripes's Avatar
Exactly. Don't cut through the part that curves down and touches the pipe you're saving. Basically cut it 90%, then pop the last part with a screwdriver. Otherwise you'll probably nick the tubing underneath. My statement will make mush more sense as you start to cut.
dalynchmob
Feb 19, 2015 07:20 PM
Jlo
Feb 3, 2015 09:41 PM
crazypurgatory
Jan 12, 2015 10:45 PM
pologreen97z
Dec 2, 2014 10:42 AM
Timberwolf
Aug 9, 2002 11:24 AM
