Heater Hose Hole
Old Dec 28, 2007 | 01:47 PM
cvccbum's Avatar
Heater Hose Hole
I have a hole in the steam hose shown in this picture.
http://shbox.com/1/tb_bypass.jpg
The part with the hole connects to the waterpump and back to the metal part with the bleeder screw.
Do I have to buy that whole thing or can i just replace that little bit of hose? and does anyone know what type of hose that is?
thanks in advance !
Old Dec 28, 2007 | 02:46 PM
BUBBA's Avatar
Are you referring to the steam pipe that is coming from the passenger side rear head or what? Go back to sh.box.com and look at the hose diagrams for the heater-----the hoses you show, I believe are for the by-pass mod which does include a "steam pipe" but it does not connect to the water pump. Get back to us.
Old Dec 28, 2007 | 06:03 PM
cvccbum's Avatar
Oh, nah. I'm talking the heater hose that goes onto the water pump. I have already bypass'd my throttle body but its the L shaped hose that connects to that bleeder valve.
Doesnt have to do with the steam one, oops!
Its to the left of the thermostat!
Old Dec 28, 2007 | 06:43 PM
You can just replace the part of hose that has the hole.
Old Dec 28, 2007 | 08:23 PM
greenmachinedriver's Avatar
the heater hose is ana ssembly thet has both hoses and the bleeder that comes all together. it is expensive too i bought one i think it was around 100 bucks.
Old Dec 28, 2007 | 09:59 PM
blwnlt4's Avatar
Ok this might sound ghetto but its an easy cheap fix that works well.
If it is leaking around the crimped fitting where the bleeder is located ( in front of the alternator) then use a blade only from a hack saw ( or a pipe cutting tool) and cut the crimped fitting off, cut away the leaking peice of hose and slide the hose further down onto the bleeder tube.
Old Dec 28, 2007 | 10:01 PM
blwnlt4's Avatar
Oh yeah and be sure to use a hose clamp.
Old Dec 28, 2007 | 10:07 PM
All parts of the hose are available separately, as well.
magman
Apr 15, 2016 03:08 AM
drt
Sep 27, 2015 04:39 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
