heater hose ?
Old Nov 8, 2005 | 08:33 PM
jayrod's Avatar
heater hose ?
I have deleted heat and a/c but I was wondering if its okay to cap off the heater hose ends at the water pump. I currently have them looped. Thanks. I just want as much stuff out of the way as possible I know that might be dumb to some but I want a clean engine bay before I repaint it.
Old Nov 10, 2005 | 04:37 AM
Guest47904's Avatar
Guest
Re: heater hose ?
Since you're only concerned with painting it. Cap it, paint it and then put the loop back on.
Old Nov 11, 2005 | 12:11 PM
jayrod's Avatar
Re: heater hose ?
Sorry, you misunderstood. I want as much clutter out as possible so I was wondering if I could leave them capped, that way I could get rid of the hoses all together.
Old Nov 11, 2005 | 04:56 PM
Guest47904's Avatar
Guest
Re: heater hose ?
Not an expert at water flow but since the heater core has a restrictor in the flow path any way. It should not be a problem to cap them. However, I don't see how a 6 or 7 inch piece of hose in front of the water pump is clutter?
Old Nov 11, 2005 | 05:12 PM
jayrod's Avatar
Re: heater hose ?
Every liitle bit helps my friend plus it looks kind of rigged being looped like that.
Old Nov 11, 2005 | 05:37 PM
1racerdude's Avatar
Re: heater hose ?
Take the hose fittings out and put some nice allen head,flush mount pipe plugs in it.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
