heater core check valve, do i need it? *pics*
Old Oct 3, 2007 | 03:03 PM
bufmatmuslepants's Avatar
had a pinhole leak between the waterpump and this check valve because the hose between them was deteriorating on the inside. i cut off the crimps to replace the hose and the valve came apart. the hose going from the valve to the heater core will reach the waterpump but im not sure if i need this part or if i can just clamp the waterpump directly to the heater core. this is the hose going from the passenger side bottom of the waterpump.
other question, if i do need this part is it a GM part or can i get it at any auto parts store? thanks
Old Oct 3, 2007 | 03:21 PM
camarozz95's Avatar
Mine actually broke and I ended up having the whole heater hose assembly Don't think you can replace just that part, but I think i have heard of people just putting a regular piece of hose in its place. Maybe somebody else will know for sure.
Many people have left it off without any apparent problems.
Old Oct 3, 2007 | 05:26 PM
CheshireCat's Avatar
I'm curious as to what that valve is actually designed to do...
I replaced mine a few years ago when I was replacing all the soft hoses and it looked like it was designed to reduce the flow through the heater core... But why?
Old Oct 3, 2007 | 06:54 PM
Yes, it is listed as a flow reducer. Possibly to eliminate any noise through the heater core, though I think it may be a factor in the frequent clogging issues with the core.
Old Oct 4, 2007 | 05:39 AM
lt1andy's Avatar
I believe it protects the heater core from excessive (high) water pressure from the water pump.
Old Oct 4, 2007 | 06:55 AM
Isn't the pressure going to be the same everywhere in the system?
Old Oct 4, 2007 | 08:54 AM
It would seem that reducing flow through the heater core would contribute to clogging in the heater core... I never considered the potential noise factor... My fan is loud enough that I doubt I'd hear it...
Old Oct 4, 2007 | 09:53 AM
i kinda figured that since the waterpump is driven by the cam, at high RPMs it keeps the pressure from getting too high in the heater core. i think im just gonna leave it out for now, and maybe eventually ill put a new one in, unless someone comes on here saying theyve had catastrophic failure because they left it out.
Old Oct 4, 2007 | 10:17 AM
94Z28WP's Avatar
I bypassed that valve a while ago without any problems.
Old Oct 4, 2007 | 10:42 AM
LT1inaMGB's Avatar
Here is some interesting reading on heater core failures.
http://www.carquest.com/common/downl...eplacement.pdf
It says thaterosion of the core can take place if the flow/pressure is too high. That's why the OEM's put in the restrictor.
Jim
Old Nov 7, 2007 | 08:33 AM
Red96Lt1's Avatar
Originally Posted by LT1inaMGB
It says that erosion of the core can take place if the flow/pressure is too high. That's why the OEM's put in the restrictor.
Pressure will be the same as shoebox pointed out. The restrictor slows the velocity of the fluid.
Old Nov 8, 2007 | 08:54 PM
Purplemaroz28's Avatar
by reducing the flow the pressure would be reduced, because it goes from the check valve i.d. to the heater hose id and using Bernoulli's equation show this will limit the pressure
Old Nov 8, 2007 | 09:12 PM
Red96Lt1's Avatar
You would only have very slight pressure variations because of the restrictor. Pressure has to be equal in a closed system.
Old Nov 9, 2007 | 10:01 AM
GOFASTER's Avatar
Maybe this is the problem with my heater. I am pulling that pos off tonight and replacing the whole hose.
