heat issue...please help
Old Aug 9, 2010 | 06:22 PM
  #16
moparman's Avatar
If the air dam is missing, the car is guaranteed to run hot.
Old Aug 9, 2010 | 09:54 PM
  #17
IanAndElisha's Avatar
We got one back on it and it was still doing it
Old Aug 27, 2010 | 04:27 PM
  #18
Angry
New water pump radiator thermostat fan relays fixed the air dam and still getting hot. Please help losing patience and ready to junk it!
Old Aug 28, 2010 | 01:17 AM
  #19
Guest47904's Avatar
Guest
Originally Posted by IanAndElisha
Is there a way to check the waterpump?
We got the fans working right now but it got to 3/4 on the gauge and was holding for a bit even with AC running then I hit a bump in the road and the oil pressure dropped low and the temp got up to the red in a couple of blocks.
You check the water pump by viewing fluid movement in the radiator.
Someone asked what the actual temp was that it got to when the fans came on. So what is it REALLY not what the gage says? What temp is the PCM seeing? Maybe it's thinking it's colder than it actually is and doesn't start the fans at the correct temp?
Since you hit a bump and the oil pressure gage went south, I would think you have a wiring issue that seems to be effecting at least the temp gage. No?
Old Aug 28, 2010 | 03:35 AM
  #20
brucer's Avatar
check your coolant temperature sensor...
make sure all your hoses are routed correctly...
with the car running look in the radiator and make sure there is coolant circulating, you should have a steady stream coming from the steampipe into the radiator..
Old Aug 28, 2010 | 07:04 AM
  #21
grumpygreaseape's Avatar
find a mechanic that can block check your cooling system. it is a chemical test to determine if combustion gasses are present in the cooling system. or find a tool truck or supply house that can sell you the kit and perform the test for yourself. you may have a leaky head gasket, or cracked cylinder head castings.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
CARiD
Sep 30, 2015 05:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
