Heads, with out the cam.
Old Nov 3, 2005 | 10:59 AM
Grims's Avatar
I am sure this has been posted before, but I’m sure you guys got nothing better to do anyway ;P
How much of a HP gain will I see from putting ported heads on my car with larger valves (sorry don't have any numbers) with the stock cam, will all bolt ons. (LT headers, CAI, other basic stuff)
Also, will it help when spraying nitrous?
Old Nov 3, 2005 | 11:04 AM
97bowtie's Avatar
Re: Heads, with out the cam.
You'd probably gain 20-30 rwhp depending on the quality of the heads.
Nitrous will flow through anything. If you're asking if the heads will 'amplify' the gains you see with the nitrous, not really.
Old Nov 3, 2005 | 11:07 AM
Grims's Avatar
Well I was thinking with increased intake and exhaust I may be able to up the nitrous more safely than if I did not have head work done.
Old Nov 3, 2005 | 11:51 AM
97bowtie's Avatar
The only thing that will make nitrous 'more safe' is a stronger bottom end. The end result of nitrous is increased cylinder pressure, which puts more strain on the bottom end...the only way to be 'more safe' with increased cylinder pressure is with a stronger bottom.
Old Nov 3, 2005 | 11:53 AM
Grims's Avatar
I have always heard of nitrous blowing head gaskets....with ported heads wouldn't the risk of blowing a head gasket be decreased?
Old Nov 3, 2005 | 12:23 PM
Mean Green's Avatar
if you open up the chamber size of the heads, the comp ratio should drop a little, so effectively it is dropping the cylinder pressure. however i doubt it's enough of a drop to say it's making it safer to run higher jets.
if you're still on stock internals i'd be more worried about detination destroying your pistons rather than your bottom end breaking due to running higher jets.
Old Nov 3, 2005 | 12:26 PM
Grims's Avatar
I run it real rich on the spray, should help.
Old Nov 3, 2005 | 03:46 PM
Jameslt1TA's Avatar
I dont think you would gain anything "worthwhile" by just porting your heads. If your gona do heads, you might as when do the hotcam kit instead, it would be cheaper and make more power than the stock cam and ported heads would.
Old Nov 3, 2005 | 03:51 PM
Grims's Avatar
well I got a set of fully done heads just sitting here....so just seeing if it was worth the effort to put them in.
Old Nov 3, 2005 | 04:34 PM
faded93bird's Avatar
Heck yeah, I would. Who cares what other people think on here.
It will cost ya about 100 bucks and a weekend.
As for the N2O the only thing holding you back are the pistons. But if you keep it rich and have a good window switch, I have seen a 200 hit on a stock short block last a while not forever but a while.
Old Nov 3, 2005 | 04:40 PM
BeaversTA's Avatar
some good reading
http://web.camaross.com/forums/showthread.php?t=398891
Old Nov 3, 2005 | 08:36 PM
speedmiser's Avatar
With the stock cam, I dropped 4 tenths going from stock heads to ported GTP heads/intake and 1.6 rockers, with no additional tuning. Sorry can't remember the mph changes though - it's been a number of years since my car was that close to stock
oldschool
Feb 9, 2016 09:21 PM
Sauced
Apr 12, 2015 10:18 AM
StansZ28
Feb 19, 2015 07:39 AM
alex5366
Feb 17, 2015 08:12 PM
pimpss96
Feb 12, 2015 01:28 PM
