Heads off
Heads off
So tommorow I'm finally going to get the heads off my Z. Basically I'm just repairing the stripped out sparkplug hole with a helicoil. Is there anything else that I should do while the head is off? Or can I just repair to hole and then bolt it back in?
Re: Heads off
While the heads are off, I'd have new lt4 springs put on (if the car is high mileage) and have the heads decked. If you have the heads decked, might as well get a 3-angle valve job while they're at the machine shop.
Also, if you want a few extra hp, use a impala head gasket (.029 thickness compared to .049 camaro/firebird). With this, your compression will be 11:1. From what I've gathered, this increase in compression will gain up to 6% hp. I have this and have no problems with it.
Re: Heads off
You are not going to gain 17+ hp from a head gasket change.
Aside from that, I would recommend everything that redcamaro said, he's right on the money. You might as well do the other maitenence items while you are at it.
Added peice of mind and insurance on the engine.
Re: Heads off
Hmm....the new springs sounds good. What about cleaning them before I bring them to the shop? Do I just whipe them down or should I not mess with them so much? I have a set of Mr. Gasket .026 gaskets so I think I'm alright in the trying to raise compression there.
Should I got ahead and get new valves too? Or are the stockers ligit peices?
Thanks for the replies
Victor Lamb
Aug 26, 2017 02:52 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
