Heads and cam swap question
Old Jun 20, 2004 | 11:49 PM
96birdlt1's Avatar
I am in the middle of a heads, cam, and LT swap.
After taking off the heads and looking into the cylinders, the pistons have a little carbon build up on them.
My question is do I need to clean off the carbon?
If so, do they need to be removed from the engine?
And what to use to clean them?
By the way the cylinder walls still have the swril marks, so I don't think that they need to be honed.
Joe
Old Jun 21, 2004 | 12:00 AM
cmillard's Avatar
I'd leave them alone, nothing to be gained there that you couldn't running a can of seafoam through there.
If you're going to have your heads off for any length of time I'd spray down the bore and any exposed surface with WD40 so nothing rusts.
If the heads will be off more than a few hours I'd seal the surface off with tape, you won't regret it.
Hope this helps,
-Christian
Old Jun 21, 2004 | 12:03 AM
96birdlt1's Avatar
I am pretty slow at this as I am making sure that I am doing everything right. I will spray them right now, and thanks for the tips.
Joe
oldschool
Feb 9, 2016 09:21 PM
birdblack
Dec 30, 2014 06:59 PM
chuyz28
Nov 25, 2014 11:14 PM
Queens94z28
Nov 20, 2014 06:03 PM
NED4SPD
Sep 16, 2002 10:45 PM
