heads/cam parts cost
besides the heads/cam what do the other parts add up to about? i just got a job at autozone so some stuff i could get 30% off
trying to get a ball park before i go ordering ****. i want the le2 set up, its either that or a supercharger
Re: heads/cam parts cost
Of course you'll need some gaskets. Get the Impala SS headgaskets as they are thinner and will increase your compression a little. Be sure and drop the front of the oil pan before you pull the timing cover off, or you'll rip it and need a new oil pan gasket
You'll need a new timing set, aerosol parts cleaner, oil, filter, antifreeze, etc.
NewsBot
Dec 17, 2014 02:50 PM
