Heads/cam m6s that went to 4.10
Old Dec 1, 2003 | 03:24 AM
unTAmedLS1's Avatar
How much did your et drop after you switched gears and what happened to your mph...Thanks
Old Dec 1, 2003 | 08:52 AM
93ZM6Tally's Avatar
Don't have exact numbers because along with the gears came ET Streets which made a large difference themselves. Also put in a 227/233 CC cam from Combination Motorsports.
Prior to Gears and Slicks (w CC305) cam:
13.3 @107.6
2.1. 60 Ft
After Gears, Slicks and Cam:
12.63 @ 111.59
1.73 60ft
Car has a little more in it with the current setup. I was bouncing off of the rev-limiter and my clutch is going. BTW I'm dumping the clutch at only 4k. My torque arm is cracked and the clutch ain't right. Biggest difference is that you hit the end of the quarter at peak RPM and no need to even consider shifting into 5th.
Old Dec 1, 2003 | 12:32 PM
unTAmedLS1's Avatar
You know whats weird is I ran that same mph and time but it was with a 2.2 60' so I wonder what would happen with traction
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
colts0455
Jul 24, 2015 04:51 PM
