Heads
Old Sep 22, 2007 | 08:22 AM
lt1loudmouth07
Guest
Posts: n/a
Heads
I Broke 2 bolts in my head because of my headers how hard is it to take off just the driver side head
Old Sep 22, 2007 | 09:23 AM
dangalla's Avatar
i can tell you the drivers side is easier due to not having any accesories other than air and coil mounted to the front
is any of the bolt's sticking out of the head at all? have you tried an easy-out?
Old Sep 22, 2007 | 09:27 AM
lt1loudmouth07
Guest
Posts: n/a
heads
it is sticking out alittle. i am doing this now because on my way to work today my header gasket blew. when i get home i will have to see if the bolt is sticking out enough where i can get it out with some tool do u know anything i can use
Old Sep 22, 2007 | 09:54 AM
dangalla's Avatar
if you did not already, get the header right out of your way, if it is sticking out a little then you can try to get a rounded nut removal socket on the stud that is sticking out, or they also make a stud remover that you hammer onto the stud. find out what exactly you have to work with first
Old Sep 22, 2007 | 12:22 PM
hsyr's Avatar
Maybe I'm not reading you right but by the sounds of it I would take the header right out before trying to remove the head itself.
Old Sep 22, 2007 | 11:40 PM
mrmint69's Avatar
I had a bolt break off in my block. I was able to get a drill and drill a small hole and insert a special bit from Sears and back it out. Hopefully it is in good location.
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
