headlights
headlights
I have a 97 trans am and when I lock the car the headlights pop up and go back down and start making noise. Is this bad motors or maybe some other problem? Need some help before I spend the money and buy motors. thanks
It's not the motors, it's the plastic gears inside the motors. Do yourself a favor and do a search for this topic, there are many links that talk about a brass gear that a guy on this board makes so you do not have to dish out $$$ for a new motor.
There's also a way to actuall turn the gears 180 degrees to use the side of the plastic gears that are not damaged, those should come up in your search too.
jackpawt883
Sep 10, 2015 08:53 PM
Aug 17, 2015 09:50 AM
Henson071
Aug 4, 2015 09:32 AM
