Headlight problem
Headlight problem
For some reason, I have to turn the switch a few times for my lights to pop up.. The lights turn on, just dont pop up.
Is there one relay for both lights?? Could this be going bad or is there something else?
Had this same problem too. I bought Brents gears, installed them and it fixed all my problems...Even the grinding problem I had with my head lights.
http://www.bfranker.badz28.com/headlightfix/index.htm
You will see that you can fix your headlight without spending any money but they will eventually go bad again, I would say, get Brents gears and be done with it.
Hope that helps,
Claude
Hope that helps,
Claude
Hope that helps,
Claude
Hope that helps,
Claude
Thanks though
Originally posted by bobbykokinos
Its not the gears, its something electrical.. I had that gear problem before and its not the same as Im having now.
Thanks though
Thanks though
Cuz I had ALL of these same exact problems plus more (grinding noises at times) with my old gears but when I replaced them with Brents Gears...They seem to work fine now. I have had his gears for over a year in my car now.
Thx,
Claude
ARE YOU POSITIVE?
Thx,
Claude
ARE YOU POSITIVE?
Thx,
Claude
ChrisFrez
Feb 15, 2015 08:12 AM
