headlight motor
Old Mar 13, 2005 | 04:30 PM
FASWS6's Avatar
headlight motor
When I turn my headlights off on my '97 TA they close fine, but the motor on the driver side makes a noise until I open the door. Does this mean that the motor is starting to go out? this is weird!
Old Mar 13, 2005 | 06:28 PM
RiceKillerZ28's Avatar
Re: headlight motor
my 97 ta did that too, get some lubricant and applicate it to the motor and make sure it glides when your done with it and it should work fine... it worked for me until i totaled it friday... if anyone wants a parts car or knows anyone who wants to buy it for parts or to restore it was a 1997 formula with 70k miles (70068) it only has to have the frame mounts changed on the front and a few new things (radiator airbox etc...) enging and trans(6speed) are fine.... i hope it works for you i really loved my car im sure you feel the same aout yours.
Old Mar 13, 2005 | 06:30 PM
Lower's Avatar
Re: headlight motor
See Brent's page here. The free fix at the bottom will get you some more time on the existing setup (will eventually fail again), but upgrading to his gears will eliminate the chance of this happening again.
Old Mar 14, 2005 | 01:22 AM
FASWS6's Avatar
Re: headlight motor
Thanks a lot man! You saved me a lot of money! It works like a new one!
ChrisFrez
Feb 15, 2015 08:12 AM
94Z28LS1toLT1
Feb 10, 2015 10:19 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
CaRParts102
Dec 6, 2014 08:45 AM
