headers and gaskets
Old Dec 29, 2005 | 01:47 AM
scottslt1z28's Avatar
headers and gaskets
my felpro gaskets dont want to match up perfectly to my pacesetters.
if the bolt holes match up then the D-port holes are NOT PERFECT and if the D-port holes are matched up the bolt holes are NOT PERFECT.
however i think the gasket matches the head perfectly.........Defect??
or common???
if so will the part of the gasket thats in the way get burned off after a few hundred miles? or will it just foul out the gasket...............and i will have to replace it later..........what should i do????
Thanks, later
Old Dec 29, 2005 | 01:49 AM
lt11997's Avatar
Re: headers and gaskets
The felpros matched up perfectly with my Jet-Hots. I've also heard of pacesetters flanges not being straight sometimes, you might want to check that with a straight edge. Are you sure you got the right gaskets?
Old Dec 29, 2005 | 02:04 AM
YUP
Old Dec 29, 2005 | 02:09 AM
i dunno, does it really matter???...................i already put the left one in because i figured thats how it was suppose to be and it would burn off later.
I REALLY dont want to take it off........but should i take it off and dremel the excess gasket off or just buy something else......like a percy metal gasket and use that instead
Old Dec 29, 2005 | 09:04 AM
97WS6SCharged's Avatar
I usually buy the Mr. Gasket ultra seals. I would remove the gasket and trim it with a razor knife, or try a different set. Who knows, maybe you got the one set in 5000 that went into the machine crooked.
Old Dec 29, 2005 | 09:11 AM
Joe 1320's Avatar
I'll never use anything but Percy's dead soft aluminum ever again. IMHO, with the limited clearance in a f-body engine bay, I hate to do things twice. If a bolt backs out, a regular gasket burns through and you'll be taking it all apart to put in a new gasket. With Percy's, just retorque the bolt.
Midnight_Z
Feb 16, 2016 09:36 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
4586
Apr 29, 2015 01:43 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
rick350
Mar 16, 2015 02:59 PM
