Headers Completed! Thoughts & Worries
Old Jul 26, 2004 | 11:40 PM
96redformula7's Avatar
Well I did the Mac single cat conversion and I am very pleased. The car pulls so so much harder on the top end it is unbelievable. However, is it possible that I lost some of my low end torquieness?? I am wondering why it seems that my powerband got shifted up into the higher rpms and I lost some in the low rpms. I am thinking maybe I am feeling this way is not because I lost any in the low end, but because I gained so much it made the low rpms seem like I lost some. I reccomend this setup to everyone, plug access is great, just changed my plug wires in less than an hour.
Old Jul 27, 2004 | 12:35 AM
Re: Headers Completed! Thoughts & Worries
Backpressure maybe?
Old Jul 27, 2004 | 07:51 AM
stereomandan's Avatar
If everything is hooked up correctly, you will gain TQ and HP EVERYWHERE.
Check out this link of a stock LT1 dyno vs what I dynoed with your same setup.
Click Here
Backpressure is bad. It does not gain you low end TQ. It's an old myth.
Dan
Old Jul 27, 2004 | 08:30 AM
Red96Lt1's Avatar
When I dynoed before and after headders, I gained more in the top end and mid range. I only got a few down low. So that's probably why it "seems" like you lost some, just because you didn't gain as much on your low end. When I got a tune from Ion, it flattened out my torque curve again.
Old Jul 27, 2004 | 09:04 AM
96TransamConvt's Avatar
I was also thinking about going to the 94/95 style headers with an OR Y pipe.
Did all of your AIR and EGR fittings mate up properly ?
Also did you have to fab up any exhaust extensions to connect to your cat back ?
Old Jul 27, 2004 | 09:55 AM
besz28's Avatar
you know what when i first put my long tubes on i would have swore my car was less torquey down low,but a trip to the dyno said the opposite, maybe i think the different sound and reduced backpressure might make it feel like that but i assure you you picked up power throughout the entire power band.
DirtyDaveW
Dec 1, 2016 05:37 PM
alphaauto
Feb 5, 2015 05:25 PM
Sandersen511
Jan 13, 2015 03:49 PM
