Headers aint worth a "darn" (edited by moderator)
Headers aint worth a SH*t
i put slp headers on my car and i gained only about .5mph in the quater mile i thought they would give at least 3mph and 2-3 tenths off the e.t., i only made my time better by adding the stall and the drag radials, i dunno how some people 's car runs better with them when i didnt gain anything
Re: Headers aint worth a SH*t
I have SLP shortie headers on my car. At first I could feel the difference but it wasn't anything major. Then I took the cats out and I was in business!!!! Bye the way, SLP shorties are the best bolt on shorties out there. However, long tubes are always better!
IMO AS&M's are the best headers as far as quality. SLP's are fine though, they are 1 3/4 and lots of ppl run them.
On my car, i picked up 3 tenths with the headers, all these times ar based on 2.3 60' times which are the best i can get on my clutch. But the MPH went from 102 to 104..............
One of my very good friends had TPIS headers and they started to rust after 2 years. Then he switched to SLPs and he is very happy with them. They at least come with lifetime warranty!
Before I would go telling everyone about how headers don't do squat, I would see if I am getting any false knock from them, maybe check my AFR with them, make sure there are no leaks and put weather in the equation when comparing times.
Headers by themselves aren't all that great... they're more of a preliminary mod for other stuff. IE: heads/cam. It's all about increasing the flow. Put a cam on without headers, and you'll be disappointed in the cam. etc.
It is only one part of the power package... Cat Back, Intake, Programming...
Then Head/Cam. You won't notice much right away. You've got a cut out so I figured you tried that. I've got a 1995 with a single cat, when I install the Off Road Pipe and remove the Cat for the track... Big Difference!
when i put my slp's on i gained about .3 in the 1/4 and at least 3 mph. my 60ft went down by about ..1 or .2 after the headers i did gers, and didnt see any gain at all exept for maybe .5 mph, other than that it just FEELS faster, which is ok but whats the point in just feeling faster if it really isnt?
but overall i was very happy with my slp's.
Originally posted by Black_Z28
TPIS's headers come coated from Jet-Hot, so if they started to rust it's not their fault. He should have called TPIS and I'm sure they would have taken care of him. Or at least called Jet-Hot. They also have a warranty on their coatings.
If your not going to get longtubes the only other header even worth thinking about are Macs. They are more of a mid length, flow awesome, and have the best plug access I've seen on a header for the LT1. All my friends who have shorties run Macs, and all have seen great gains, my friend who had SLP's just switched them to Hooker LT's. I say Macs or longtubes are the only way to go.
I gained almost 2mph in the 1/8.
