Headers
Old Feb 24, 2003 | 01:38 PM
ollie-99's Avatar
Headers
Im gunna coat my headers w/ some high temp paint
Should i sand them down first? they have been sand blasted
what grit should i sand them w/
Old Feb 24, 2003 | 01:45 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: Headers
go for it, but i doubt the paint will last.
i have yet to see paint last on headers
good luck with it thought
Old Feb 24, 2003 | 02:25 PM
neil350's Avatar
Hahaha dont waste your time, the paint just turns white and burns off.
Old Feb 24, 2003 | 02:39 PM
Dave19yz28's Avatar
http://web.camaross.com/forums/showt...threadid=82946
HTH
Old Feb 24, 2003 | 02:42 PM
rotoruter2001's Avatar
get em coated
Old Feb 24, 2003 | 03:13 PM
95_RipperZ's Avatar
HTH
That stuff sounds cool. I am going to try that to patch up my FLP collectors where they began rusting.
Old Feb 24, 2003 | 08:36 PM
Black bow tie's Avatar
I've been building Hot-Rods long before the advent of these modern coatings. Here's what I'd do, if they have been sandblasted then just clean them with contact cleaner, blow them off (if you have compressed air), then shoot them with VHT Flameproof paint (following the instructions on can for coatings). This stuff will outlast any other header paint IMO, but of coarse if you can afford to get them coated, I would. VHT can be had from Schucks, Jegs and I think Summit.
Old Feb 25, 2003 | 09:09 PM
ollie-99's Avatar
whats contact cleaner???
like soap and water?
Old Feb 26, 2003 | 11:12 PM
ollie-99's Avatar
what can i clean the headers with???
Old Mar 4, 2003 | 10:28 AM
Go to any auto parts store and get "brake cleaner" or "electrical part cleaner" or even "carb and choke cleaner"(aerosol cans), more or less the same as contact cleaner. They clean, then quickly evaporate. Make sure you use these outside or you'll get as high as a glue sniffer.
Old Mar 4, 2003 | 08:42 PM
Mtrhds94Z's Avatar
Acetone, lacquer thinner, MEK is cheaper[since it isn't 'aerosol' ]
What you want is an oil free solvent...
[not Gumout carb cleaner either stuff like that has a 'film' in it]
Having been sandblasted is good.. not glassbeaded, but with silica sand, etc[better than sanded]
sherwinZ28
11
Aug 15, 2015 05:38 PM
colts0455
Jul 28, 2015 11:28 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
