Header Wrap
Header Wrap
I'm having problems with my headers melting the spark plug cap on number 8 cylinder. Is header wrap electrically conductive? I figure that this may help.
Thanks in advance
Thanks in advance
Re: Header Wrap
Originally Posted by OBE1 95Z28
Header wrap will soak up oil over time and be a fire hazard. I would suggest getting some heat resistant wires like the Accel 9000s.
Header wrap is a bad idea. You could also put shielding around the plug wire along with Accel 9000s.
Header wrap can also rust your headers through and cause holes.
Re: Header Wrap
the only way they would melt that cap is if they were touching.
a nice solution is to use spark plugs that have a shorter ceramic "tower".
ACCELs are shorter.... as are most AC delco plugs.... just look for "header" or "Shorty" plugs and you'll find several.
carguyshu
Jan 22, 2017 11:19 AM
NewsBot
May 19, 2015 09:30 AM
