header question please help!!!
Old Mar 2, 2003 | 08:21 PM
JKDZ28's Avatar
i have a 93z with mac headers (almost)
well im having a problem gettin the passenger side header on because its slightly bent (i suppose).
for the end bolt to bolt up ( right under the alternator bracket ) its coming up short a few centimeters
should i try bending it while its up in there, or do i have to unbolt it clear everythikng out and pull the header back out
any help is greatly appricated
Old Mar 2, 2003 | 10:22 PM
Polo-94Z28's Avatar
If you bought them new... I'd try and send them back... if thats not possible, just do it right, take it out and fix it. A leaking header can cause several problems, false knock, bad air/fuel mixtures, poor emissions and even burned valves. (somewhat rare)
Other than that... not much you can do other than get another set.
Laterz
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
