header paint
Old Mar 15, 2006 | 05:55 PM
dubbsix's Avatar
header paint
hey all. i won a set of MAC mids on ebay.. they have some rust and i wanted to know the best/thickest paint to put on them.. any ideas?
Color doesnt matter.. i am going to wrap them in header wrap (black) anyhow.
Old Mar 15, 2006 | 06:32 PM
disco192's Avatar
Re: header paint
Dont use header wrap... it traps moisture and makes them rust and will screw up the paint.
Just get them coated.
Old Mar 15, 2006 | 06:47 PM
dubbsix's Avatar
Re: header paint
Thanks for the heads up! I thought it would help them stay coole runder temp.. so i wont have heat shields anymore...
So how hot do the headers get? i dont want to burn up anything.
Old Mar 15, 2006 | 08:00 PM
OBE1 95Z28's Avatar
Re: header paint
Tom Byrne burned a F-Body to the ground using header wrap. It will absorb any spilled oil which can ignite.
Old Mar 16, 2006 | 08:11 AM
Re: header paint
When you wrap headers, the carbon steel tube reaches basically the full exhaust temperature, which is over 1000degF. Carbon steel is not intended to operate at these temperatures. It starts to oxidize (rust) from the extreme heat, not from trapped moisture. Then the steel and the welds start to crack.
The correct solution is a cera-metallic coating (e.g. Jet Hot, although they seem to be having a lot of problems) on both the inside and outside of the tubes. That keeps the heat inside the header, increasing scavenging, and significantly reduces the temperature outside the headers.
Old Mar 16, 2006 | 08:26 AM
WS Sick's Avatar
Re: header paint
If you do paint them , clean them thoroughly, bead blast and then use an outdoor cooker paint good to 1500 degrees. Now this will not reduce the heat radiating from the tubes, but will keep them from rusting..... for a while.
Old Mar 16, 2006 | 11:14 AM
dubbsix's Avatar
Re: header paint
Well first... is the heat generated by the headers and issue? Will it burn up stuff? I dont have the money for a Ceramic coat job..
Old Mar 16, 2006 | 11:16 AM
wrd1972's Avatar
Re: header paint
Jethot coating is the best.
Also POR-15 has a special silver high temp header paint, however I have never used it.
Old Mar 16, 2006 | 11:19 AM
dubbsix's Avatar
Re: header paint
Hmm i might look into the POR 15 thing. How much does it cost to have a set of headers coated with Jet hot?
How many people have non coated headers and dont have any heat issues under the hood?
Old Mar 16, 2006 | 11:42 AM
OBE1 95Z28's Avatar
Re: header paint
Header heat will tax your spark plug wires; guys running uncoated headers usually end up buying heat sleaving for their wires to keep them from failing. Not sure what a set of heat sleaves costs, but you might factor in their cost into you decision.
Old Mar 16, 2006 | 11:56 AM
dubbsix's Avatar
Re: header paint
OBe,
thanks. Sleeves sound like a good idea and alot cheaper than having my headers coated.
Old Mar 16, 2006 | 01:29 PM
Sweetred95ta's Avatar
Re: header paint
Don't paint them. I tried painting mine with a high temp paint (VHT, I think) and properly baked it on there with short running times, and it eventually turned white and came off. Some spots had paint on them still, but the "hotter" spots burned the paint off. It did work as a coating for a little while though.
Old Mar 16, 2006 | 02:14 PM
dubbsix's Avatar
Re: header paint
Well my concern is that they have a bit of rust on them.. I am going to have them bead blasted to get rid of the rust and then cross my fingers with having them painted with some type of heat reisistant paint. I am getting the feeling that i should have just bought the headers new.
Old Mar 16, 2006 | 02:29 PM
wrd1972's Avatar
Re: header paint
I priced my RK sport headers and y-pipe and it was like $320.00
Mondo expensive.
Old Mar 16, 2006 | 03:38 PM
dubbsix's Avatar
Re: header paint
I just called jet hot and they said they would totally redo the headers.. inside and outside coating for 199 dollars, plus shipping. Not too bad.. I am thinking it would actually be cheaper to have them do it right than to have a local machine ship d!ck around with it.
