header gaskets
Old Nov 12, 2004 | 10:34 PM
ericz28w's Avatar
header gaskets
well anyway i was trying to save $$$ and bought cheep gaskets and now im paying for it, i got all kinds of leaks and was wondering what gaskets u guys are using? i hear the stock ones are really good ??? i have no idea
let me know
thanx
Old Nov 12, 2004 | 11:18 PM
Dave88LX's Avatar
Re: header gaskets
Red RTV.
We'll see how it works.
Old Nov 12, 2004 | 11:39 PM
Bud M's Avatar
Re: header gaskets
Congratulations! You have started the one millionth post about header gaskets!
This is a good example of when to use the search function.
Old Nov 13, 2004 | 12:05 AM
ericz28w's Avatar
Re: header gaskets
thanks alot man, i kinda have the worst internet and computer possible and takes me for ever to do any thing and was wondering if u guys could narrow it down for me, but i guess u would rather be a *****
Old Nov 13, 2004 | 12:55 AM
cmking26's Avatar
Re: header gaskets
I used copper gaskets. Some people have problems with em, but they worked perfectly for me. The key is to check your header bolts a couple times until they aren't backing out anymore.
Old Nov 13, 2004 | 01:07 AM
Bud M's Avatar
Re: header gaskets
Wow, sorry I hurt your feelings. Thought you might have a sense of humor.
Old Nov 13, 2004 | 03:54 AM
CamaroBoy96Z28's Avatar
Re: header gaskets
I use the Fel-Pro 1406 gaskets...no probs here.
Old Nov 13, 2004 | 04:10 AM
Spinner's Avatar
Re: header gaskets
Only gasket I've ever had success with was an earl's ultra seal aluminum gasket with silicone carbon inserts.
Old Nov 13, 2004 | 08:08 AM
T/A#4's Avatar
Re: header gaskets
Fel-Pro, no problems after 5000 miles.
Old Nov 13, 2004 | 08:26 AM
tbsimmons's Avatar
Re: header gaskets
I agree been used for over 2 years, and no leaks.
Old Nov 13, 2004 | 09:40 AM
dirtybird96's Avatar
Re: header gaskets
Fel-Pro, 6 months and no leaks
Old Nov 14, 2004 | 01:50 AM
ericz28w's Avatar
Re: header gaskets
thanks guys
Old Nov 14, 2004 | 01:54 AM
mongse_1's Avatar
Re: header gaskets
I'm using the Earl's Pressure Masters on the turbo motor. Same thing as what was described above. 1406's should work just fine, but with all header gaskets, remember to check the bolts after a few 100 miles or so. Doesn't matter what kind of gasket you use, the bolts WILL BACK OUT. The only way to avoid this is to use locking bolts (Stage 8) or the Breslin bolts.
Old Nov 14, 2004 | 02:28 AM
Cmr0z28's Avatar
Re: header gaskets
Old Nov 14, 2004 | 08:14 AM
97FormulaWS-6's Avatar
Re: header gaskets
ONLY ones I've ever gotten to seal up and STAY sealed...
Not to mention they are made for Earl's by Parker-Hannifin which is one of the best/largest gasket/seal makers in the world.
