header gaskets
well anyway i was trying to save $$$ and bought cheep gaskets and now im paying for it, i got all kinds of leaks and was wondering what gaskets u guys are using? i hear the stock ones are really good ??? i have no idea
let me know thanx |
Re: header gaskets
Red RTV. :)
We'll see how it works. |
Re: header gaskets
Congratulations! You have started the one millionth post about header gaskets!
This is a good example of when to use the search function. |
Re: header gaskets
thanks alot man, i kinda have the worst internet and computer possible and takes me for ever to do any thing and was wondering if u guys could narrow it down for me, but i guess u would rather be a prick
Re: header gaskets
I used copper gaskets. Some people have problems with em, but they worked perfectly for me. The key is to check your header bolts a couple times until they aren't backing out anymore.
Re: header gaskets
Wow, sorry I hurt your feelings. Thought you might have a sense of humor.
Re: header gaskets
I use the Fel-Pro 1406 gaskets...no probs here.
Re: header gaskets
Only gasket I've ever had success with was an earl's ultra seal aluminum gasket with silicone carbon inserts.
Re: header gaskets
Fel-Pro, no problems after 5000 miles.
Re: header gaskets
Re: header gaskets
Fel-Pro, 6 months and no leaks
Re: header gaskets
thanks guys
Re: header gaskets
I'm using the Earl's Pressure Masters on the turbo motor. Same thing as what was described above. 1406's should work just fine, but with all header gaskets, remember to check the bolts after a few 100 miles or so. Doesn't matter what kind of gasket you use, the bolts WILL BACK OUT. The only way to avoid this is to use locking bolts (Stage 8) or the Breslin bolts.
Re: header gaskets
Re: header gaskets
Not to mention they are made for Earl's by Parker-Hannifin which is one of the best/largest gasket/seal makers in the world. |
