Header Gasket Problem
Old Jul 13, 2003 | 10:38 PM
Jim_H's Avatar
I know this has been beat to death but I am having problems getting the passenger side gasket to seal. It blows out after 100-200 miles.
The reason is most likely because the old gasket was stuck on the header and I could not scrape it all off. It is not easy to get razor blades in there with the header in the car. Anyone have ideas to get the old gasket off the header?
Old Jul 14, 2003 | 12:49 AM
kirschman's Avatar
take the header loose at the y-pipe. That should give u enough room to move the header around. Not sure what type of header ya got, mine got the ball type flange, so no gaskets is needed at the bottom. Use factory gm metal gaskets, they will give u a leak free seal, I promise
InfernalVortex
Jan 17, 2015 09:35 AM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
