Header Gasket
Old Jun 6, 2005 | 02:43 PM
SubsAnDubs's Avatar
Header Gasket
I was wondering what is a good header gasket to pickup. I need to pick up one tonight or order it online. I have the Mr.Gasket on there already and have burned 2 of them up. Part of the problem is because of the poor design of the Pacesetter shorties. I was looking for a heavy duty one and if you could tell me where to pick it up or post a link to the online store it would be appreciated.
Old Jun 6, 2005 | 03:06 PM
BUBBA's Avatar
Re: Header Gasket
What do you mean by "poor design". If you are having a hard time sealing, different gaskets aren't the answer.
Make certain the flanges on the headers are flat as can be. Take them to nearest machine shop and have them checked and ground down if necessary.
Then get some Fel Pro 1406s along with some 1 " ARP 12PT bolts and slap'em on.
Retighten after a couple of heat cycles and you should be good to go.
Doesn't hurt to check bolts every so often. JMHO
Old Jun 6, 2005 | 04:59 PM
lt11997's Avatar
Re: Header Gasket
felpro 1406 d-port
Old Jun 6, 2005 | 05:07 PM
matt65's Avatar
Re: Header Gasket
I had a similar question the other day, you may find good info there also.
http://web.camaross.com/forums/showthread.php?t=372569
Old Jun 6, 2005 | 05:13 PM
BUBBA's Avatar
Re: Header Gasket
I dunno. There just something about buying a gasket from a guy named Earl that bugs me. Kinda like picking up a set of Leroy's heads, cams and assorted tires.
Midnight_Z
Feb 16, 2016 09:36 PM
dylan1303
May 22, 2015 12:24 PM
4586
Apr 29, 2015 01:43 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
rick350
Mar 16, 2015 02:59 PM
