header confussion on lt1
Old Nov 16, 2004 | 06:12 PM
jerame20's Avatar
Question header confussion on lt1
ok guys i have a bit of a stumper here i have 96 ws6 i just installed pacesetter lts and custom y pipe and 3 inch pipe all the way back, went ahead and did plugs wires and compression test while i was in there anyway the problem is now the car runs strong when cold but as soon as it warms up it starts stumbling bad when under a load ie. in a high gear or at wot. the car never missed before i have checked all vaccum lines done the run in the dark looking for shorts nothing. i installed lt4 km thinking it was pulling time when it got out of closed loop but it didnt help i am thinking it has to be something with the computer and am saving for a dyno tune if anyone has any other ideas and/or knows a reliable affordable place to get a tune in the fortworth area please reply.
thanks guys
Old Nov 17, 2004 | 01:56 AM
whatsup's Avatar
Re: header confussion on lt1
Sounds like O2 sensor(s). Did you install new ones? Might have damaged during install. Wires might be touching headers.
Old Nov 17, 2004 | 03:34 AM
Fastbird93's Avatar
I would think O2's also just due to the fact that you did a header swap and that seems to readily kill O2's while the new headers are going through it's first few heat cycles buring off all the extra gunk.
Old Nov 17, 2004 | 11:08 AM
Built on Sin's Avatar
I just did the same install and I have similar problems. Only my car won't idle after it warms up. Is there a way to clean the O2's?
Old Nov 17, 2004 | 11:16 AM
BigEvil's Avatar
I have a similar problem. Mine idles fine, but after it warms up the SES light comes on. I'm sure it's my O2's since my A/F is reading constant rich, which it didn't before.
Old Nov 17, 2004 | 11:22 AM
HardcoreRM125's Avatar
Mine did the same thing, it was a bad O2 ... It was so bad that coming up even small hills, id have to downshift and keep it above 2800ish ? Or it would start bogging and ****.
Old Nov 17, 2004 | 12:19 PM
Red96Lt1's Avatar
I guess you could unplug your 02 sensors and see if the problem still exists.
Old Nov 17, 2004 | 02:31 PM
BackNBlack's Avatar
It sounds like a good idea to use your old o2's for the swap them have new ones handy afterwards? I am about to do my headers and I have the new o2's still in the box. I was going to do them at the same time but it sounds like its best to wait?
Old Nov 17, 2004 | 07:02 PM
jerame20's Avatar
really the o2s you think i am not getting any codes thrown and i dont think its shorting out anywhere on the wires i crawled under it with it running in the dark no light show. i will try the o2s i guess. keep the ideas coming i am probably going to get a tune too if anyone in the dfw area has a recomendation.
Old Nov 17, 2004 | 08:37 PM
Fastbird93's Avatar
Yes.
dmcdonald96
Jan 30, 2015 06:46 AM
Jason Short
Jan 19, 2015 06:34 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
Jul 4, 2005 05:00 PM
