header bolts backing out
Does this continue FOREVER or after a few times of tightening them back up it will stop backing out? Should I look into locking header bolts or maybe take the bolts that are backing out and loctite them?
What bolts are you using now? SB 1" long. Not unusual for bolt to loosen at first few heat cycles. One should check them every once in awhile anyway----important to have the correct tools available to make job easier.
I guess there are some locking systems that work well, but I wouldn't opt for any that require you installl little bitsy locks lest you risk losing them in the F Body black hole. I use ARP stainless, with 12 pt heads that give me a tad more room between the primaries and the bolt head. Had to tighten one that was backed out, but seem to be ok now---1" length good idea, since it gives you a margin of safety when the bolt does back out, i.e, at least it won't wind up on the highway. JMHO |
yeah it seems 3 backed out on the passenger side header, both on the first primary and then 1 on the second/third primary... I was only able to reach the second and third bolt... first one was hiding under the alternator... I guess I'll need to take it off and then tighten it down.
Would it be OK to run with 1 bolt already somewhat backed out but the rest tightened down?... I'm going on a trip tomorrow morning and won't have time to take the alternator off today so I can reach the first bolt |
Originally Posted by Mortify
(Post 4582708)
Stage 8 locking header bolts can be a best friend. I installed them and never have to worry again
ALso another thing that I forgot is there was a rubber tube running from a hex box in the front driver side of the engine bay, to a T fitting connecting to the old stock manifold, then running to what looked like the EGR valve in the back of the intake, I still have that tube attached to that box, what does it do?
i guess i just got lucky... the ones i used were the ones i got from pacesetter... i checked them a couple of times and they never backed out
3 week and 3 times i tightened them. The first time all needed a little to a lot. The next time only 6 needed a tiny bit and last time just 3 and they were real close. I figure next time it should be almost done. I would be careful not to let them go to long because the sealent can blow out and its time to remove and redo. It a good time to check plug wire to be sure none are touching or very close.
Originally Posted by njenson
(Post 4582808)
Originally Posted by Roach02
(Post 4582763)
Stage 8 or other locking will usually always solve the problem. |
