header bolts
Old Feb 18, 2007 | 02:32 AM
riodealz28's Avatar
header bolts
i just bout some used pace setter headers and i just wanted to ask out of this bolts which are the best and should i use treat lock is which treat lock blue or red and what gaskets ? http://www.sdpc2000.com/catalog/195/...olts-Studs.htm
Old Feb 18, 2007 | 02:42 AM
69gto96z's Avatar
Get you some 1" stage 8 locking header bolts part# 114-8911-A
http://www.thunderracing.com/catalog...vid=4&pcid=301
Then some Felpro gaskets part# 112-1406
http://www.thunderracing.com/catalog...&vid=4&pcid=54
I would get em all from thunder racing, you wont find a better deal on the gaskets, and dont use any threadlocker, get some high heat anti-sieze compund.
Old Feb 18, 2007 | 04:34 AM
2000GTP's Avatar
Agreed on the above post, Stage 8 locking bolts and a set of Fel-Pro 1406s will do the trick and please do stay away from the threadlocker.
Old Feb 18, 2007 | 09:58 AM
95LT1conv's Avatar
IMO stage 8's suck. nothing worse than getting a bolt tight and having to back it off to get the lock to line up. i'd go w/ ARP 1" stainless
Old Feb 18, 2007 | 04:49 PM
salty's Avatar
I went with the above mentioned ARP bolts, and had no problems-I rechecked them after a few heat cycles to check for loosening, however.
No leaks yet!
Old Feb 18, 2007 | 04:50 PM
JoeliusZ28's Avatar
i used breslin locker bolts on my pacesetters and i love em. however bad news is i heard they went out of business
Old Feb 18, 2007 | 05:05 PM
Z95m6's Avatar
I agree, stage 8's suck. They also seem like a really soft metal. Its very easy to round the corners off and round out the center of the allen head. I removed all of mine and just replaced them with a set of Mr. Gasket brand bolts, from Autozone. Also i'd stay away from locktite, if anything put anti-seize on them.
Old Feb 18, 2007 | 07:22 PM
OBE1 95Z28's Avatar
Anytime you thread a steel bolt into an aluminum head, you want to use antisieze grease as dis-similar metals will create a galvanic reaction and cause corrosion. Threadlocker is the wrong way to go; it doesn't stand up to temperature anyway.
Old Feb 18, 2007 | 07:27 PM
94/96ZsM6s's Avatar
i used the bolts pacesetter included with the headers. there had been no problems leaking at all in 10k and all i did was put anti-sieze on the bolts
Old Feb 18, 2007 | 08:16 PM
Texas_96_Z's Avatar
I used the Pacesetter bolts and the copper gasket they supplied, no problems so far. I did have to tighten them up a few times however.
89TramsAmGTA's Avatar
The best combination I have found so far is the Earls header gaskets and the Breslin locking bolts. This combination has been rock solid. No leaks
Old Feb 18, 2007 | 09:50 PM
ttop1986's Avatar
Thats what I have. No problems so far.
Old Feb 19, 2007 | 01:29 AM
riodealz28's Avatar
this 1ns look good what do yall think but wich 1ns the 1st 1ns or the second prt # 4667 or prt #4668
http://www.spectreperformance.com/#CATALOG.4668
check in the performance fastiners section
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
maybe2fast
Mar 16, 2015 09:45 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
