Header Bolt Thread Size?
Old Dec 17, 2009 | 02:18 PM
19z28camaro02's Avatar
Whats the Header Bolt thread size at the cylinder head? And whats a good rule of thumb for determining the length needed?
Old Dec 17, 2009 | 02:24 PM
NJ-LE's Avatar
19z28camaro02:
I assume this is for after market headers.
3/8" x 1" x 16 tpi. 3/4" is the common length but 1" works and is less likely to loosen and cause leaks later.
Old Dec 18, 2009 | 12:37 AM
RamAir95TA's Avatar
Go with a 1" bolt, as long as you have the clearance to get them in.
What headers are you going with?
Old Dec 18, 2009 | 10:28 AM
dhirocz's Avatar
Another vote for 1". 3/4" tends to only grab the last few threads, then you run the risk of the bolt coming loose and falling out, or stripping or pulling the threads in the head to get them to spec.
I prefer header studs myself.
Old Dec 18, 2009 | 09:27 PM
Dave1980's Avatar
Yeah but are those a possibility with LT1 engine bay?
Old Dec 18, 2009 | 09:52 PM
I don't like Stage 8s and I've decided i'm gunna go with the 1" because I'll have clearance and I don't want to have to mess with them. I' also have a decent flange size on the LPP headers.
Old Dec 19, 2009 | 04:18 PM
JAKEJR's Avatar
The diameters and threads are based on the heads being used. The length, however, is just a matter of measuring because the thickness of the header flanges and the gaskets can differ from header to header and gasket to gasket.
Easiest way I've found is to stick something straight into all the head exhaust bolt holes, then measure how far it went in. Write down the results. I say "all" because it's possible that the depths of the holes are different due to head design and manufacturing tolerances/differences.
To that number you would add the thickness of the header flange and the gaskets.
Now you'll have the over-all distance number to work with.
From that you must subtract the clearance amount you'll need to keep the bolt(s) from bottoming out in the head. I'd give myself a 1/8"-1/4", but no more, in order to maximize the amount of thread engagement. Going less than 1/8" would depend on the accuracy of your measurements, so I'd play it safe and stay at or just above 1/8".
Just how I'd do it.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 2010!!!
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
cyteone
Feb 7, 2015 06:04 PM
ChrisFrez
Jan 11, 2015 03:47 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
