header bolt removal
Old Aug 7, 2009 | 01:07 PM
hghpwr's Avatar
header bolt removal
O.K last week I posted about a header bolt that won't come out,so I decided to hack saw the head off and try vise grips on what was left sticking out ( about a 1/2 in.),of course this a@#$%^ bolt still will not even budge even a small amount and I don't want to pull the heads so does anyone think heating the stud will free it up? I did not see any anti-seize on any of the bolts I took out.
Old Aug 7, 2009 | 01:26 PM
Sick97SS's Avatar
PB Blast the hell out of it and let it have a good soak. what i've done is use a dremel to cut a deep notch in the head of the bolt, then use a flathead screwdriver to unscrew it.
Old Aug 7, 2009 | 02:29 PM
hghpwr's Avatar
Ihave used aero kroil several times doesn't move .001 of an inch even with the largest vise grips I have so I don't think a screw driver will do anything, but thanks for the suggestion.
Old Aug 7, 2009 | 04:40 PM
joeSS97's Avatar
Tap on the bolt a few times. Heat the cyl head with propane. The heat will make it expand,you dont want the bolt to expand.
Old Aug 7, 2009 | 04:51 PM
boosted-lt1's Avatar
Heat, lube, and then hit it with an air chisel. Repeat.
-Scott.
Old Aug 7, 2009 | 10:39 PM
hghpwr's Avatar
I am going to try and double nut the stud sticking out and if that doesn't work I will try heating the head. Thanks
Old Aug 7, 2009 | 10:58 PM
Kevin Blown 95 TA's Avatar
I would heat it - is it a stock stud? they had locktite on them and heat will loosen it.
Old Aug 8, 2009 | 10:01 AM
hghpwr's Avatar
Its not a stock bolt,its the header bolts that came with the jba headers,they have been on there for 9-10 yrs and the jerk mechanic I had install them didn't use any anti-seize and or cross threaded the bolt. I had to hack saw the head off to remove the header.
How long should I heat the head,and I would think any lube would catch on fire?
Old Aug 8, 2009 | 11:22 AM
Did you try rapping it a little to loosen it? If you heat it use a good hot torch and don't go too long.
Old Aug 8, 2009 | 11:44 AM
hghpwr's Avatar
I am definetly going to rap on it a bit,purchased a propane torch kit .That should do the trick hopefully because I don't want to pull the head and with 113k,or else i'm pulling the whole top end.thanks
maybe2fast
Mar 16, 2015 09:45 AM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
thenewkid
Nov 18, 2014 12:57 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
