header bolt question
Old May 17, 2004 | 08:16 PM
Got-LT1's Avatar
Will header bolts for any SBC work on the LT1 or do they need to be Lt1 specific?
Old May 17, 2004 | 08:57 PM
Red_94Formula's Avatar
They will work. Any sbc bolt will work. Just compare the new one to the old one to see if they are differnt.
Old May 17, 2004 | 09:36 PM
My Red 93Z-28's Avatar
does ARP make locking header bolts?
Not to hijack the thread or anything, but how do you guys tighten up the header bolts on the #8 cylinder???
Old May 17, 2004 | 11:02 PM
Got-LT1's Avatar
I mangage to get in there with a 7/16 box wrench, you can only get a little turn on it and it takes forever but it works.
Old May 18, 2004 | 02:05 PM
That's what I was using, but after a full rotation on the firewall side of the #8 primary, it wouldn't hook on again.
Old May 18, 2004 | 03:22 PM
Red96Lt1's Avatar
I couldn't even get a boxed end wrench on any of my bolts. I had to grind down a wrench to make it fit.
Old May 18, 2004 | 05:19 PM
93midnightta's Avatar
i used the breslin bolts and they worked awesome. i had to grind down a few different shape wrenches to get them to fit next to the primary but with a lot of patience we got them in.
Old May 18, 2004 | 06:35 PM
1996 | Z28 SS's Avatar
The very back one on the passenger side? I went at it from the top... I used a shallow 9/16 socket and a flexable ratchet. Wasn't too bad.
Old May 18, 2004 | 07:48 PM
9/16?
Mine are 7/16
I'll give it a try but I think I might of already ruined the gasket.
Old May 19, 2004 | 12:51 AM
med_reject's Avatar
i had the exact same problem. U need a stubby wrench. I got breslin bolts, which work with a 3/8" donut hole, but the donut hole cant get around the bit because it bumps into the header
Old May 19, 2004 | 01:51 AM
25thBird's Avatar
I couldn't even tread the bolt in, so i left it out hoping for no leaks. I was lucky enough not to have one when i turned it on.
Old May 19, 2004 | 02:50 AM
CoUnTryMuZiCZ28's Avatar
Any bolts will work.. I never use locking bolts and i havent had a problem.. I use the ARP 3/8 bolts.. those are what i use on everyones headers i put on.. no ones had a problem come to think of it, and you can get a small 3/8 deep socket on almost all of them and tighten them down very well.. the rest i use a normal 3/8 open end wrench..
Old May 19, 2004 | 10:30 AM
med_reject's Avatar
other than 1" long vs 3/4", how are the arps any different than the regular header bolts? No matter how many times i tightened the regular ones and what protocol I followed, they kept coming loose, and so i bought the locking ones
Old May 19, 2004 | 01:30 PM
Its not the length.. Its the heads on the arps.. they are alot smaller allowing sockets or wrenches to clear the primarys.. I use loctite and tighten them all.. i havent had a problem..
ChrisFrez
Jan 18, 2015 08:05 AM
ChrisFrez
Jan 11, 2015 03:47 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
