head thread striped
Old Mar 18, 2007 | 11:12 AM
94blk-lt1's Avatar
head thread striped
i bought new heads from this site and my last head thread on the passanger side is striped and also the third thread on same side. its the one that bolts the manifold on. i already put the head on the engine in my car.
i read a few threads on this but i am still unsure on how to fix the thread. do i have to take the head out? what do i have to buy to fix? and, how to you fix it? is this a fairly easy job to do? i am sure i have other questions but i cant think of them right now.
any advice would be great! thanks
Old Mar 18, 2007 | 11:30 AM
JP95ZM6's Avatar
You need a Helicoil Kit of the appropriate size. I have fixed stripped threads in Aluminum with Helicoils, and that is the typical method. If you can find room to get tools in there you can do it on the car. A right-angle air drill with a shortened bit will work in very tight quarters.
Example:http://www.plymouthlaser.com/heli.htm
I am assuming you mean exhaust. Could do intake on car too but don't get any chips in there! Grease on the tap helps catch all the chips.
Good luck.
Old Mar 18, 2007 | 02:07 PM
94blk-lt1's Avatar
nah, its the intake manifold. where do i get the kit at? at a parts store like auto zone? is there a way that i could limit the amount of metal shards that get into the engine?
Old Mar 18, 2007 | 02:08 PM
94blk-lt1's Avatar
oh, is this a pretty easy jod to do?
Old Mar 18, 2007 | 03:13 PM
mdacton's Avatar
pull the intake off.....but an old sheet or something in there and tape off the intake ports......carquest or napa should have the kit you need take an intaqke bolt with you.....a kit will come with thread tap, helicoils a drill bit and an install tool.......some people put threadlock on the helicoil so it won't back out when you take the bolt out.
Good luck, its a pretty simple fix
Old Mar 18, 2007 | 03:44 PM
94blk-lt1's Avatar
so then i dont need to pull the head? thats great! lol
about how much does it kit cost?
thanks for the advice guys
Old Mar 18, 2007 | 03:47 PM
mdacton's Avatar
you don't need to pul the head...just the intake. and keep everything clean.
The good kits run about $40 or so.....I would get the kit that has everything in it...bit,tap, etc.
The cheaper ones are a pain if you have never done it before
Old Mar 18, 2007 | 03:51 PM
94blk-lt1's Avatar
are you sure i wont have to pull it? there are 2 threads that are striped. the one on the back and the 3rd one both on the passanger side. it is kinda deep in the firewall.
Old Mar 18, 2007 | 09:24 PM
As long as you can get to it and do the work, the head can stay were it is. You must be able to drill straight and carefully.
Old Mar 19, 2007 | 12:59 AM
lt11997's Avatar
It is very important that you drill straight like shoebox said so take your time.
Old Mar 24, 2007 | 10:15 PM
94blk-lt1's Avatar
ok...i think i might ****ed up! i did the heli coil but the new thread is too big for the bolt. i got the right kit (7/16-14 with a 7/16 drill bit). i did everything in the directions but i guess i messed up. well, i know i messed up since it does not fit. what do you guys recomend me do? i doubt there is nothing else i can do. can a machine shop still fit this or have i messed up my new 1500 dollar heads. gosh i really hope i didnt mess them up!!!!
Old Mar 24, 2007 | 10:42 PM
mdacton's Avatar
man did you take the bolt with you when you got the kit??????????
ITS a 3/8" bolt slim....it can be fixed, but damn its important to take your time with this stuff......take it as a lesson learned.
Just pull it and take it to a machine shop and get them to fix it
Old Mar 24, 2007 | 10:48 PM
3/8-16 for intake and exhaust manifold bolts. 7/16-14 is for the bolts in the block that hold the head to it. Dang, who told you to get a 7/16 helicoil? Couldn't you tell it was way too big?
Old Mar 24, 2007 | 10:50 PM
94blk-lt1's Avatar
you know what.....i did take the damn bolt but the idiots at auto zone must have gave me the wrong stuff. i hate when they look at you like you dont know what your talking about.
anyways, so it is fixable? thanks god. i am soo pissed right now cuz of auto zone. how will they go about fixing it?
i have learned a good lesson in this. take my time and auto zone people dont know ****!
Old Mar 24, 2007 | 11:01 PM
mdacton's Avatar
it could be fixed several ways....just get the hole welded up and re-tapped
