head studs or bolts?
Just got my shortblock back from the shop , and wanting to know what is going to be best before I order.
I will be running 383 LE3/4 with a very possible 200 shot in the future. Should I use studs? I know that some have had issues with leaking from not getting them to seal at the bases.
Motor should be coming together soon people.
So I need to ask what my builder used in the honing process?(fasteners) Can you please explain further as to why? Are you referring to the torque plate fasteners? What kind of difference would there be?
I am going to go with bolts, I would also really like to know what 96capricemgr meant however. SnakeatinZ you agreed with him, what does he mean?
Dave
The need to use the same fasteners that will be used to assemble the engine to mock things up during the boring/honing process is an acknowledgement of the fact that the stresses placed on the block by the clamping force of torquing the heads may vary if studs are substituted for bolts. If the clamping force is varied by changing the type of fasteners, the final shape of the cylinders may be affected and ring seal compromised. While builders frequently favor studs, bolts will work nicely for most applications. In my own case, the need to periodically remove a cylinder head from the motor at the track, in the car, for certification procedures makes studs relatively impractical. I started with bolts and they're still holding the heads on so I suppose it's a moot point in this instance.
Sounds like you have a very similar setup to me. I have head studs, although I wish I went with bolts. As others have said I dont think they were needed, makes r&r of heads difficult with engine in car, and many complain of leaks. Not worth it IMO.
